ca hydralics |
Post Reply ![]() |
rilenz ![]() Bronze Level ![]() ![]() Joined: 23 Dec 2022 Location: WI Points: 64 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Oct 2024 at 11:40am |
hope I put this in the right place now. Is it fairly easy to repack the hydralic cylinders on a CA. I like to do the work myself
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87409 |
pretty easy to do... after you get the packing nut loose ... just pull it apart.... have you tried just tightening the packing nut ? that can work if seal is loose and not old / hard/ cracked.
Edited by steve(ill) - 16 Oct 2024 at 5:53pm |
Thanks Steve(ill) looks fairly easy. I'll look at the manual while doing the repair and give update when done.
Post Reply ![]() |
