Can you machine a Allis 160 flywheel
CleaningGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CleaningGuy Quote  Post ReplyReply Direct Link To This Post Topic: Can you machine a Allis 160 flywheel
    Posted: 11 Oct 2024 at 10:51am
Hi all,
I'm working on an Allis Chalmers 160 flywheel (see picture attached) and had a couple of questions about machining it. Specifically:
1. Can the flywheel be resurfaced using a normal stone wheel, or does the pressure plate mounting surface need to be milled separately to maintain proper alignment?
2. If I were to remove about 0.010" or 0.020" from the clutch face, how can I ensure that I maintain the correct clutch clamp force? Are there any adjustments needed to account for the material removed?
Any insights or tips from someone with experience on this model would be greatly
appreciated.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 2:44pm
Flywheel step must be .175
Post Options Post Options   Thanks (0) Thanks(0)   Quote CleaningGuy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 12:41pm
Yeah, I understand it can be machined to a .145" step, but how do you machine the middle portion where the clutch assembly mounting bolts? Most machine shops around here only have two types of grinding wheels, and I'm not sure if they have the right equipment for this part of the job. Do you know if there's a special tool or process required for that middle section? Or would milling be the better option?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 10:58pm
Take it to the machine shop and let them determine if they can do it. When they did my Cat flywheel they cut the disc surface then raised up and cut the mount surface to establish the step.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 5:33am
Any competent machine shop will have a grinder that will handle that. Tractor flywheels all seem to have a step.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 7:07am
 The problem most common machine shops have doing these is because the pressure plate step is below the disc surface .I have a machine shop that can do these . Been doing these a long time .
     Maybe post another picture showing this step a little better.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CleaningGuy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 1:58pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 2:33pm
My machine shop resurfaces  the clutch surface ,then mounts in a Lathe and cuts the recess .
    I just wanted you to post a picture of recess so those who never seen this type flywheel clutch set up can  understand it's not like most 2 step flywheels.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 3:50pm
Ok, I will ask, why is it designed this way?
What does the outermost step up do, other
than get in the way?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 9:53pm
got to have weight to make torque
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2024 at 8:52am
Next (possibly stupid) question incoming. Why the step down for the pressure plate mounting surface?  Surely would be more cost effective both in initial manufacture & in subsequent repairs to have it level with the friction surface & have the pressure plate mounting surface .175" less proud of it's friction surface?
Edited by ekjdm14 - 15 Oct 2024 at 8:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 6:45am
 Having any luck on flywheel getting anyone to do it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CleaningGuy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 12:45pm
Yeah ended up getting taken care of. The shop said they'd mount it in a lathe to get the step right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 1:37pm
As I said above been getting them done for years that way . Any good machine shop would know how to do them .
This page was generated in 0.126 seconds.
