Whats it really worth?
Lwencl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lwencl Quote  Post ReplyReply Direct Link To This Post Topic: Whats it really worth?
    Posted: 02 Oct 2024 at 10:40pm
I have a 1966 HD3 with 6-way dozer, log jammer with pto winch. Undercarriage is decent, rollers idlers and sprockets are good. Engine overheated and knocks. I would say it needs a cylinder sleeve or two and maybe a piston.
The clutches are all good, as is the power director. It just needs an engine repair, or a swapped engine.
I like the machine, had it for years. I am now too old to do this kind of stuff.
My question is what is it reasonably worth as it sits?
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2024 at 7:28am
Non-running prices start at scrap. If it is a Buda diesel that makes it harder to repair as parts for Buda are harder to find. Yesterdays Chicago auction will give you an idea.
http://lonsallischalmers.com
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2024 at 1:30pm
Prices are dropping on things like that…
Due to inflation of parts prices it now makes it not worth much.
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2024 at 11:55pm
I'm guessing it shouldn't be very hard to replace the diesel engine with a gasoline one out of a D15,with as many D15 as there are around with trashed transmissions should be able to find a motor.A little dozer like that would be pretty handy around the farm.Just picking a number out of thin air I'd say at least $1,000.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 9:49am
The other side of the story is it has USABLE UNDERCARRIAGE. Where else can you find more. Priceless.
But I will concede it may take years to find the person wanting undercarriage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 10:10am
Engine parts for the diesel are hard to come by. Engine repairs in general are expensive. The injection pump rebuild (if it has been sitting) will shoot $750 bucks minimum. And like all dozers...it's heavy and hard to move when it doesn't run.
