Puller 190xt with 426 engine
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Topic: Puller 190xt with 426 engine
    Posted: 30 Sep 2024 at 5:09pm
190xt with 426 engine. Could sell a couple different ways. Has stock 426 with hardened rods, Kentucky 2 disc clutch, Atlas shift collar for two speed high/low. P-pump with ice intercooler. Cap brother hubs with firestone 23 degree 18.4-38. wheelie bars custom hitch roll bar weight brackets. solid front axle. weighs roughly 6900 lbs. always pulled road gear. Rear end is squeaking so I'm guessing I need to fix rear spider gears that maybe seized.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2024 at 8:44pm
do you have a number to call
phil
Newallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 3:39pm
Out of curiosity, what all did you have to do to put a 426 in it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2024 at 5:27pm
Make backing plate out of a 7580 type backing plate by centering/laying 301 plate over 426 plate. Grind some material off newer 426 block for a 301 starter. Starter is then mounted where a 301 is located. custom flywheel made to 301 size
