185
Mallettfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mallettfarms Quote  Post ReplyReply Direct Link To This Post Topic: 185
    Posted: 28 Sep 2024 at 1:27pm
I’ve got an injector line that leaks but can’t find a replacement for it and unsure if other models will fit the 185.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 7:16pm
Wheres it leaking ? Rubbed a hole in it ? Theres thousands used out there , just make sure you get the right one for that cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mallettfarms Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 8:01pm
Yea it has rubbed a small hole it on cylinder 1 I can’t seem to find them at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 8:13pm
Usually a pretty easy brazing job. I've fixed a dozen or so in the last 4 decades.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 9:57am
I have a parts 180 and a couple of power units if they would be the same. I know there are some lines left on them.. I have braised them in the past.... thanks.. Dale
Edited by orangereborn - 29 Sep 2024 at 9:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 7:30pm
Have nos line 4020109 fitting prior to SN/2D-26977
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mallettfarms Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 7:32pm
I’ll have to go check and see what the serial number is I know it’s a 1975
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 8:51pm
Engine s/n not chassis.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2024 at 8:15am
guessing sn change is for american bosch injectors? The injection line should go in the top of the injector on a bosch injector. Not many of those made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2024 at 8:58am
They had at least two different line sets over the years for the A-C injectors. The early lines were different because the injection pump had that aluminum spacer between it and the engines front plate. Later engines the pump sat 3/8" farther forward so the lines were changed to accommodate that new location. Then came the Bosch injector lines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2024 at 9:42am
Thought all 185's were new enough to not have the long shaft, and adapter spacer. Thinking also, only very early 180's had the long shaft. The 180/185/190 lines are different than a turbo 190XT though, due to the oil cooler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2024 at 10:24am
AGCO parts books isn't very helpful. They have the 180 and 185 lumped together and just show the change prior to and effective at engine s/n 2D-26977. Doesn't specify which model tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2024 at 7:30pm
I just looked in numerical book and says 4020109  fits 180,190
