CA Hydraulic Adjust Screw B
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Hydraulic Adjust Screw B
    Posted: 15 Sep 2024 at 5:54pm
It appears that screw B, plate lock, was ripped off at the attachment with the left plate. I have both the screw and the threaded part. The plates appear to be locked regardless of the screw being missing. Is this press fit into the plate or threaded? Repair suggestions? I'm inclined to clean up the end so it fits square and weld it.
Edited by dfwallis - 15 Sep 2024 at 6:54pm
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 8:21pm
the two plates are held together with a snap ring #34... if the NUT is ripped off the plate, yes you can weld it back on to thread  "B" into it..
Edited by steve(ill) - 15 Sep 2024 at 8:22pm
