6060,6070,6080 Brake fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 6060,6070,6080 Brake fluid
    Posted: 12 Sep 2024 at 3:57pm
Impossible to find the SAE10W-10 oil for the brake reservoir on these tractors. I have 1 in need of fluid that I’m repairing for a friend. What is everyone using? I was told Dextron 3 was an alternative?
Thanks Rob
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2024 at 4:36pm
I use case IH 73344413 fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2024 at 6:08pm
Thank you Alvin, I greatly appreciate your response sir. Hope all is well in PA!
Edited by AC720Man - 12 Sep 2024 at 6:09pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 7:47am
I added some to my 6080 some years back because the 'brake oil level' light would flicker. Remember it taking a long time to figure out what to use and don't remember what it was now. Only took about a tablespoon to make the light go out! Been fine ever since. Pretty sure I talked to. Reed at the farm store and he got me on the right track for what oil to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 8:00am
I'm OK with any type of automatic transmission fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 8:05am
If they call it SAE10w... then that is a thin hydraulic fluid.. I would think, like the DR that Type F, or the old Dextron 1 or 2 would be good.... I might stay away from the MERCON LV or Dextron 6 typ "synthetic" heavy addative oils............. I have never heard of SAE10w - 10... that would be an oil that acts as 10w in the summer and 10w in the winter.. WHY put the -10 on the end ?
