Gleaner M2 wiring diagram
WD45 Aaron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner M2 wiring diagram
    Posted: 06 Sep 2024 at 5:50pm
This is a long shot but does anyone have a wiring diagram for an M2 Hydro? Specifically, I am looking for the wiring of the fuse blocks in the cab. Unfortunately, I am an hour away from the machine and the manual.
Thanks,
Aaron
Machinery rescue for all things rusty or broken. Current residents include 2-1/2 WD45s, Oliver Row 77 gas, Farmall super C, two Cat D2's, Clark C500-80 forklift, and a sick Kubota.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2024 at 6:27am
https://parts.agcocorp.com/us/en/apbsearch?q=gleaner/79012320/l&name=M2+%2F+M3+SERIES+COMBINE+%2815401-25900%29
Using your smartphone or laptop click on the above weblink. It will take you directly to Agcopartsbook.com for the Gleaner M2 & M3 series combine parts manual. Once there scroll down to “electrical & instruments” section. If you open the first listing (diagram)it will begin in the combine’s right hand console wiring(page fuse box area). It will display a diagram (photo)of that page. In the area immediately above diagram, you can use the left/right arrows to navigate page to page.
Above the arrows is a “table of content” button. It will take you back to entire M2 listings.
The “diagram” button is highlighted in red cause that’s your current location.
The “parts list” bottom will give a parts number listing for whichever diagram you’re viewing.
Remember, the site is a huge database, so be patient for searches & give time for a page to load and you’ll get along fine. Get in a hurry & not so good.
Hope this helps.
Edited by AC7060IL - 07 Sep 2024 at 6:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2024 at 7:23am
Thanks for the info. I've referenced that parts book before but I don't see an actual wiring diagram showing wire colors, where they connect, etc.
A few electrical "tragedies" have happened to the machine over the years. Some of the fuse blocks are melted and or broken. And there are broken connections. I have new fuse blocks to replace the damaged ones. I'd like to study the schematic ahead of time to get a game plan.  I believe the operating manual has schematics but I didn't think to bring it home with me last time I was working on the machine.
Thanks,
Aaron
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2024 at 9:26am
WD45 Aaron, Thanks for specifying your need.
The Gleaner M2 “Service Manual” has a schematics page for the electrical wiring per fuse box & cab console that denote wire colors per function(s), not the Owners/Operators manual.
I don’t have a M2 service manual or I would have taken a photo of said page & upload it for you. But maybe someone else on the forum does?
This page was generated in 1.039 seconds.
