D19 governor help
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Topic: D19 governor help
    Posted: 03 Sep 2024 at 4:12pm
Our d19 has started revving on its own. It will idle down with the throttle but will revv up on its own. We checked all the linkages. Nothing was bound up. So we pulled the governor off the motor. Everything looks normal. We can spin the gear and hold the weights... is that normal. To our thinking the weights should be attached to the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 6:38pm
You have diagnosed it correctly. I don't know if there's room to weld it or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 7:50pm
If I do weld it do I have to be concerned about balance? The chances of finding a new or good used one are gona be tuff!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 7:58pm
The weld will be almost in the center of the rotating mass, so balance won't be an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2024 at 4:17pm
Just wanted to post an update.
Edited by ToddnwIl - 05 Sep 2024 at 4:19pm
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2024 at 8:12pm
I have one welded like that in one my D19’s been working fine for years now
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2024 at 8:16pm
Hopefully this fix works. My grandpa bought this tractor new so it rather special to us. It grinds two loads of feed a month and rakes hay.
This page was generated in 0.197 seconds.
