Rt angle gearbox
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: Rt angle gearbox
    Posted: 30 Aug 2024 at 6:52pm
Old 7016 Simplicity. What is procedure to get cross shaft out? Down to bare shafts sticking out and don't know how to get snapring out of gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 7:52pm
assembly starts at 14:50.
Steve... am i looking at the wrong thing ?  I dont see a snap ring..
https://www.youtube.com/watch?v=ZLkO4f5CePc
Edited by steve(ill) - 30 Aug 2024 at 8:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 8:00pm
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2024 at 6:21am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2024 at 7:30am
What are you trying to do to bevel gear box
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2024 at 9:35am
That shaft he slipped in is larger dia where it shoulders gear. Mine has a wire ring. Looks like just drive shaft out of gear. I have a broken tooth gear box in running tractor and "good" gear box in parts tractor. The good box has a bad keyway on through shaft. The bad box has good through shaft. I thought I 'd just switch shafts but don't know the procedure
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2024 at 1:45pm
...shaft just drives out of gear.....
Edited by SteveM C/IL - 31 Aug 2024 at 1:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2024 at 8:32pm
The ring is a pain in but you just work it out with a pick. Usually gets bent and should be replaced. And should not have to drive gear. The ring is what holds it. There was different shafts. Depends on whether it was a gear shift or hydro or variable speed.
