WD45 transmission
iowaman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowaman Quote  Post ReplyReply Direct Link To This Post Topic: WD45 transmission
    Posted: 30 Aug 2024 at 7:05am
I have a WD45 that is stuck in first gear. I removed shift tower and everything appears to be normal. Replaced shift lever as it was badly worn but that did not help my problem. What should I be looking for?
You only live once. But if you live right once is enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 7:51am
Not sure you know what you're looking at. 1 and 2 are engaged by a sliding collar/coupler on the top shaft of the transmission. It must be located in the middle of 1 and 2 to be in neutral. I'd say you getting stuck in low gear is the fairly typical worn out shift lever/shifting lug/shifting cover socket scenario. If you would have removed the shift lever, stuck a long screwdriver down in the hole and popped it back into neutral, you'd be fixed.
