Picked up a 3 point adaptor n ended up with this
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Topic: Picked up a 3 point adaptor n ended up with this
    Posted: 17 Aug 2024 at 9:06pm
Going to make a GOOD parts tractor
nonetheless ,still dead.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2024 at 9:23pm
Parts tractir??????
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Tractor
1984 80780
1957 D14
616 tractor
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2024 at 10:47pm
Nice. I passed on a 3pt adapter at consignment auction today. It was missing the chains, top link bracket, and middle braces
Edited by plummerscarin - 17 Aug 2024 at 10:49pm
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 12:24am
What’s wrong with the d14 to part it out?
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 3:58am
Nice haul
Still got the Auction Tags hanging off them !
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 6:21am
hmm... 'needed' the tractor and plow to see HOW the adapter mounts ????Wink
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 6:59am
I see D 12 stickers on it. Nicest parts tractor I've ever seen. Thanks for sharing
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 7:19am
Not a genuine Allis Chalmers 3pt adapter. Some companies aftermarket knock off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 7:52am
OK, I have to know HOW did you decide it wasn't 'true orange' ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 8:10am
 True Allis Chalmers aficionados would see #1 it doesn't have a genuine removable AC snap coupler eye, #2 the lift links are generic shop made items, #3 generic top link mount, #4 looks to be CatII lower link balls, The genuine Allis Chalmers CA,D10/12 adapter will have CatI balls, #5 the cross bar would have a mount for the top link that would be used if it wasn't a PTO implement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 8:57am
   I bought this one because it will do what I want .
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 9:19am
Cute little rascal!
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 9:47am
This is a real A-C Cat. 1 3PH adaptor. The top link on this one attaches to the cross bar between the two main arms for use with non PTO equipment.
The top link (beaming tube) on another model made for PTO equipment connects to a bracket on the tractor like any common 3PH.
Fred's after market adaptor appears to be one of the better ones.
A-C also made a Heavy Duty (category 2) adaptor which looks similar but is made of much heavier materials.
Edited by Brian G. NY - 18 Aug 2024 at 9:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 10:11am
This is a real A-C top-link.
Allis calls it a "beaming tube".
Nice fancy hand wheel!
And an original A-C top link bracket made to clamp on the rocker shaft on the WD and WD-45 tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 10:29am
I was getting some of those handwheels made however the degrading quality of the work the foundry was doing as each successive generation took over the business has made me decide I have what I need and it's not worth it to continue getting NLA parts made anymore. Now the great grandsons are running the business and they don't see the need to produce the quality that their great-grandfather was doing, they only have to do better than the Chinese. The handwheels I have will fit right onto a generic CatI toplink.
This page was generated in 0.046 seconds.
