Cable Clamps and such
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Topic: Cable Clamps and such
    Posted: 03 Aug 2024 at 9:55am
As I have been having issues with my Range/Park cables, I finally was able to dig deep into them
I had previously remove the bolts holding down the bracket behind the hydraulic stack, lift up the whole area a bit, and tighten the allen head screws Dr. Allis tight
be danged if everying worked... until it didn't.
so I took a deeper dive into it.    What I found was the C-clamp (bit of mickey mouse POS) was broken at one of the screw holes.
So, now what.... I'm in Canada, the cost to buy/ship that little piece of metal would be silly... So, I thought, why didn't they use a solid rod C-Clamp/U-bolt like at the lever end of the cable.
So, I made one.  I went to a local hardware store, and although they didn't have any U-bolts in the size I needed, I DID find a wire cable clamp, where the U-bolt appeared to be nearly the right size.
So, I bought one, took it apart, and modified the size by forming it over an anvil of appropriate size.  I had to spread it out a bit, then insert the anvil into the C, and bring it back around so it was "JUST" slip over the groove.
This left the legs a bit wider, so I drilled out the holes (just drilled near/between the screw holes so they remain undamaged) just enough to get it to fit through.
a couple washers/lockwashers, and installed everything. (sure would be easier to have a kid there to move the lever when needed)
I could access the nuts from inside the cab, through the floor.
removing the bolt/bracket from on top the Range/Park shaft, and unbolting the ball/Socket cable end allowed enough movement to get at the nuts to tighten.
with the really snug fit on the cable groove, I didn't get too heavy handed on the nuts, only really snug with lock washers, so I wouldn't crush the cable.
I felt that the fit is better, SOLID, so there would be minimal issues with movement/slipping.
bolted down the rear bracket.
tried the lever and all felt well enough.
Fired up and ran a test.
a bit stiff as before, I assume from lack of a functioning Transmission brake, and many years of lack of lube, but worked as before.
the cable alignment is just a bit lower, which keeps the cable more straight on that the original.
IF I could have sourced an AC U-bolt that matched the front, I'd have gone that route, as I think the ends are identical, and it would have made life a LOT easier.
I'm just putting this out there, in case anyone else is having big issues with their Range/Park cable rear clamp.
I'll add, that after a few times digging into that area, the solid mechanical lever through the floor looks like a pretty easy modification.
I may look into that in the future, but for now, I have my extra 10 gears at hand.
AC7060Pd 1975
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 10:00am
Well I'm impressed ! You bought ONE 'clamp' and made it work !!!!
I'm a 'Noah' kind of guy, tend to order things in 2s (or 3s or 4s...... )
Maybe look at what Princess Auto has,if there's one nearby. Heck latest flyer shows that now carry  front tires for D-14 ! ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 11:14am
Hahahaaa
PA was where I got my cable clamp
But I noticed on the parts diagram the clamps are opposite of mine
I have the presses metal one on the back, and a C bolt on the front
AC7060Pd 1975
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 11:20am
well I'd be really,really impressed if you ONLY bought that one clamp from PA !!!
When I go there to pickup my order, I always have to walk the isles and 'somehow' decided I need this, that and oh yeah 3 of those......
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 1:19pm
Yeah Jay I have the same problem at Princess Auto in Saskatoon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 1:32pm
Oh, don't get me started on the bigger PA stores...   about double the selection of mine in P.A.
But we do what we can, Right?
I was ready to buy a long bolt, cut off the head, thread the shank, and bend it on an anvil.
if I had a few days, that would have been the better option, so it fit better.  But what I did worked OK, all I need to do is fabricate a heavier backing plate to replace the washers.  the heavy washers I had were too wide diameter, so had to use smaller/lighter ones, and my holes had to be enlarged to fit the angled legs.
AC7060Pd 1975
This page was generated in 0.083 seconds.
