2900 engine
CW2 Ryno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Topic: 2900 engine
    Posted: 29 Jul 2024 at 3:13pm
Question for you all, I haven’t had time to research but I have a 180XT that I picked up for a reasonable price that the engine is rusted badly internally.   I haven’t dropped the pan yet to look at the crank. But based on the amount of rust on the lifter end of the pushrod I’m thinking it’s going to be bad.    Found a 2900 out of a Combine that was a running engine and stored inside.   From what I assume the engine would work but would need the front and rear covers swapped and I assume oil pump, and possibly injection pump depending on if the governors are different.
Am I thinking correctly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2024 at 3:31pm
Injection pump is probably fine, but may need the low idle and high idle speeds adjusted, which is easy. WHICH 2900 engine and what model Gleaner combine and YEAR would be helpful.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2024 at 8:02pm
ENGINE
SERIAL NO
2D-52837
Hard to read the model. Waiting on the seller to respond
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2024 at 8:14pm
Means nothing to me. What did it come out of??  year and model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 6:45pm
Sorry for the slow reply that engine sold, found another out of a M2 combine. I assume swap all parts from the tractor engine over and it should work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 8:15pm
I'd assume so, but you haven't told me what YEAR M-2 or WHICH 2900 engine.  120 HP was standard and 130 HP was an option in 1978 and newer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 8:28pm
I’m having trouble getting information out of the scrappers, the engines 4 hours south of me so relying on pictures.
Appreciate all the assistance!
This page was generated in 0.176 seconds.
