B front crankshaft seal
Dale Ms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Ms Quote  Post ReplyReply Direct Link To This Post Topic: B front crankshaft seal
    Posted: 08 Jul 2024 at 12:33pm
I have a CE engine # 91611 K. Can’t locate a front oil for it. I see seals for later model of the CE engines. The part # in my parts book is 206593. I’ve been looking by putting 70 in front the parts #. No luck. Anybody know know what seal may go in that engine. Have tried part # 70225806. It didn’t fit. Any help is appreciated. I mow with this tractor an grass is growing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 1:23pm
i think your shaft is 1.500 and the housing bore is 1.938 inch..(1-15/16).... the seal you can get is a 1.942 OD  ....... check these out...
Edited by steve(ill) - 08 Jul 2024 at 1:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Ms Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 2:39pm
Thanks Steve for the reply. I’ve tried that size seal . It fits the shaft but not the bore. I measure the bore at 1.922. I’ll measure again to double check later this afternoon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 4:24pm
i thought the OLD BORE was 1.938 and the NEW BORE was 2.010 inch ??
I will double check for more info..
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 7:40pm
There were 3 different seals used throughout production of the BE/CE engines. Even if you use the serial number on the block, you can not be sure of which seal the engine uses as often parts get updated over the years when doing repairs.
  This is what I will do with every engine I rebuild, I install a speedi-sleeve over the grooves in the crankshaft and use a modern lip seal instead of the solid rubber or cork ones that come with today's gasket sets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Ms Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2024 at 7:20pm
Thanks guys . Sorry for being slow getting back to y’all. Think my plan moving forward is to purchase a common seal an have a machinist fit it to the timing cover. Paul, there are no return oil groves on the crank Probably not an original crank. Will have to put this project on the back burner. Had a D15 present with an electrical issue. It’s always something. I’ll holler to y’all later on . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2024 at 8:10pm
Dale, there have been several guys that bought the NEW seal with the 2.010 OD and had the front cover machined to FIT that seal...
