HD5 Sales Add video
Post Options Post Options   Thanks (2) Thanks(2)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: HD5 Sales Add video
    Posted: 05 Jul 2024 at 11:59am
HD5 - AC add video from way back
https://youtu.be/lBn1g_xlhVs?si=n_STn3xAjaDFDib_
Fafarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fafarms Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 2:25am
Hi, I noticed you a lot of knowledge about the hd5 transmission from another thread. I am wondering if you have the bearing numbers or specs for input and output bearings for the transmission. I am also wondering if you know of any good parts sources please let me know. Thanks.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 6:17am
I have some used HD5 parts if I can help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 10:36am
All the parts can be matched as bearings that can be found in open market that are used on AC machines - well almost - the Link-Belt bearings on outboard axle are not common nor are the cone bearing used on front idlers .
 I would need to check my books to see if i wrote numbers down , but as I had access to good suppliers - most times i just gave them the sizes and bearings showed up the next day .
 Input was easy to find - the output end is a double row radial bearing (and kind of expensive) last one I replaced I got from a customer I serviced who rebuilt clutches and transmissions - believe it was around $150 back then .
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 11:52am
It has been well over 20 years since I put all new bearing in my HD 5 transmission, but all bearings came from bearing supply house. I don't remember needing anything but shifter linkage from Allis Chalmers parts.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 5:41pm
Top machine in its day!  A real workhorse.  Imagine if it was updated to today's standard!
Orangeman
ecosse23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecosse23 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2024 at 2:28pm
Thanks for posting, rather than the quick clip I expected, it's almost like a short feature film!  I guess they had a decent promotional budget so they could stretch to a 15 minute advert. Smile
This page was generated in 0.123 seconds.
