8030 Trans Filter Light
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: 8030 Trans Filter Light
    Posted: 18 Jun 2024 at 8:33am
Had ‘Trans Oil Filter’ light come on our 8030 PS today. Filter was changed approximately 90 hours ago. Complete fluid change approximately 200 hours ago. 3400 hours on tractor. Oil level fine. What would cause this? Should filter be changed again? Bad sensor?
I should add that it was about 95 degrees out when it came on. It went off on the end rows when we let it sit but eventually stayed on the whole time. We went back to the barn with it. Pulling a Kinze 3500 planter with hydraulic drive.
Also - no change in performance, shifts flawlessly.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 1:55pm
Id start with the sensor. Had a engine oil pressure switch go bad on a 8070. Light came on in the field. Shut it down immediately. Put a guage on it and it had great oil pressure. They do fail all of a sudden
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 6:55pm
Check for the sender wire rubbed through and grounding
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 8:47pm
Thats a good suggestion. Wire grounding is a real possibility
1984 80780
1957 D14
616 tractor
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2024 at 9:56am
I’d check your wiring, common issue with the light coming on.
