175 Allis lift cylinder rebuild
kenney58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenney58 Quote  Post ReplyReply Direct Link To This Post Topic: 175 Allis lift cylinder rebuild
    Posted: 17 Jun 2024 at 11:53am
I had read once on replacing cylinder seals on the 3 point lift. Am unable to remove pin in the front of cylinder in front of axle housing. And advice?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 3:10pm
Going to need some heat and penetrating oil.  Have done it several times.  Removing the floor pan and traction booster linkage helps a lot.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 3:18pm
I know D17s4 cylinders and 175 cylinders are probably different but on my D17 i plan to just take the pin out of the rod end screw the cap out pull the rod out and leave the tube on the tractor. Am i think wrong for some reason
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
