Sickle mower options for CA
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Sickle mower options for CA
    Posted: 05 Jun 2024 at 8:34pm
I am looking into getting a sickle mower for my CA. I can't seem to find a whole lot of info about them. I'm assuming there was a mid mount one, and a snap coupler one? I can certainly see the advantage of the mid mount one for ease of viewing. But I'm leaning toward a snap coupler one for ease of mounting/dismounting. Plus, i need to load it onto a trailer, and i wonder if a belly mount one would interfere when loading/unloading. Anyone know the sizes and model numbers that fit a CA?
The mechanic always wins.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 10:18pm
Snap coupler no 7 for twin wheel drive and I have used I think it’s a no 3 semi mounted pitman stick on mine. No real issues that I remember just moved to 82t on bigger tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2024 at 6:44am
as mentioned the #7 is a Snap couple rear mounted mower. The #7 requires a heel spring assembly which the CA mounting parts are hard to find. The later version 80R is much easier to find all of the CA mounting parts as the D10/12 & CA all use the same unique pieces. The 80R has a base mount that goes in place of the drawbar bail, then the mower mounts to that.
  For side mounts the #5 is a pitman mower and doesn't have much ground clearance.  My favorite mower that I've ever had on a CA is the 80S this is ideal for a CA as it mounts the mower head a little closer to the tractor and is out front where you can watch it.
   I once had an 82S with the CA, D10/12 mounts and hated it. As the mounts are primarily designed for larger tractors, the twin-wheel head is positioned quite far front the tractor and a CA is not a big enough tractor to counter all that weight hung so far out to the side. Also the complete mower as Allis designed it hangs on the two 5/8" bolt holes on the bell housing and can easily rip out the threads of these two holes. I got this 80S from a fellow that had brought it new mounted on a D12 and that is just why he considered it scrap iron. I made extra brackets that also tied the mounting frame to the two cultivator holes in the torque tube and the two out in front of the grill. This helped the weak mount, but the balance of all that weight hung so far out to the right made the little CA unsafe on even the slightest slope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2024 at 8:58am
I found an 80R, but it is 7' and came off a WD. So did they make different 80Rs, with different bar lengths and snap coupler dimensions? I would think a CA would be better suited to a 5 or 6' bar?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2024 at 5:32pm
If you want easy to hook up and unhook get a trailer type like an 82T,used one for years to cut hay until I got a New Holland 456 trailer mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2024 at 9:23pm
I run a 6 ft side sickle on a B at half throttle.. Dont take any HP to run a sickle... I would think a 7 ft on the CA would work it you have a good buy on one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2024 at 7:44am
We mowed for 10 years with a No.7T hooked behind a CA,supposed to be one the first AC sold.
