Allis Wd 3pt Hold Function
ForgivenCreation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ForgivenCreation Quote  Post ReplyReply Direct Link To This Post Topic: Allis Wd 3pt Hold Function
    Posted: 03 Jun 2024 at 3:38pm
Does the allis wd have a hold position for the 3 point. Was trying to use the no5 mower and it was either going up or down.
I read on an older post that this has to do with the 3 point hold function?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 4:18pm
Yes it does. The Operators manual does a great job of explaining just how all the screws are to be set for different hydraulic functions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 5:38pm
When the linkage is adjusted and set-up properly for "HOLD" position work, the hydraulic lever will have a detent at about the half-way point on the quadrant. There is a large decal on the battery box side that tells you what to do to get the HOLD position working as does the Operators manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 9:55am
....and most leak off as you use it so it's not like you can set and forget. It is NOT like a depth control on a real 3 point.
