CA Valve Adjustment
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Topic: CA Valve Adjustment
    Posted: 03 Jun 2024 at 2:24pm
So I mentioned this in my water pump thread. My CA suddenly developed a pop when running that you could hear through the intake. I suspected a valve issue, but hoped for the best as engine was supposedly rebuilt when I bought it and I rarely ever ran it due to the rear wheels being rotten (which I just replaced last summer.)
So I just pulled valve cover and was relieved to see the push rod for #4 cylinder was not under the rocker arm. I pulled it out, no marks looks good.
So I thought it just came out of adjustment. But then noticed all the nuts on the four (sorry, for lack of a better term) of the "bridges or stands" that holder the rocker shaft were all loose. The nuts on the same studs that hold the valve covers on.
Are they known to come loose? Or did the last owner just not tighten properly?
And now, how much do I tighten those nuts and should I use Locktite?
I haven't looked at my manuals I have for it yet, but hopefully it has the specs for setting the clearances. Any tips would be appreciated. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 2:26pm
Everything looks nice and clean. I put lifter back in place and started it briefly and even without setting it up properly it runs almost perfect now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 2:27pm
Sorry, still can't figure out how to post multiple pics.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 4:21pm
I set the valves at .014 COLD.... that makes the clearance about .012 when the engine heats up... I have never heard of the rocker arm nuts loosening up.. I would guess they were never tightened properly.
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 12:16pm
They don't come loose. 3/8 fine thread? Probably around 30lb/ft.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 12:55pm
Shawn... one thing i have found interesting over the years... is that many rocker arms dont set dead center over the valve stem.. They seem to be off 1/8 inch or more.. been that way forever.... if you look at your second photo you can see a couple that are obvious.
dfwallis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 3:52pm
I fixed all of mine, for good or bad.  All nice and centered now.  No more barely inside the outer edge deep indention wear patterns, I hope.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 5:49pm
How did you fix them to line up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 5:55pm
Thanks for all the info everyone. I won't have time until next week to touch it again, but I ordered another timing light so I'll hopefully get her all tuned up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 5:56pm
Nearly all that was required was minor machining of the standoffs on one side (there might have been an exception, I can't recall).  Must be sure to get them nice and flat/true.  I only removed just enough to center them but no more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 6:19pm
Oh okay, thanks. Did you have to shim them at all?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 7:11pm
I don't believe that I had to add or subtract any components that were already there (e.g. washers).  They pretty much self center via spring pressure.  But be sure to think it fully through before you make any modifications.  Only do one at a time and see what the overall impact is by reassembling where needed.  I only took off thousandths at a time, trued it up, polished it and reassembled to see the result before taking any more off.  But it is possible to add shims (washers/machine bushings).
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 8:07pm
my point was it looks "ODD".... but has been that way for 70 years.. IT will probably run another 70... Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 8:12pm
True, but some of mine were so far off there was only about 1/8 inch of contact area.
This page was generated in 0.254 seconds.
