D19 Rear Axle Question
WIAllisFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WIAllisFan Quote  Post ReplyReply Direct Link To This Post Topic: D19 Rear Axle Question
    Posted: 03 Jun 2024 at 10:35am
I've had what I believed to be a leaky rear outboard axle seal for a while now, and while I was in the process of replacing the rim on that side this weekend I thought we should go after that seal as well. I'm waiting on the service manual(AC-202) to come in the mail but this question is bugging the daylights outta me.
When I got the cap off I found what seemed to be an old very rotted out gasket or seal that would have been between the axle bearings and the cap for for the final drive. I don't have good pic of the material but you can see a little chunk of it at the bottom of the housing next to the outer ring of the axle.
Is there supposed to have been a seal between the axle bearing and the cap?
Seems to me there shouldn't be because I would think the outboard axle seal and the o-ring on the cap would be good enough, but I'm not sure.
Anyone have a picture of the final drive assembly from the manual they can post?
And while I'm there should I replace the bearing as well? There is about 1/8" of play in and out, and none up and down play.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 8:11pm
There are shim's under the cap that adjust axle end play. I dont remember if Allis used paper or tin shim's
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 8:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WIAllisFan Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 1:56pm
Thanks Boss Man!
