Changing 6V to 12V |
vansequipment
Joined: 26 May 2024 Location: Washington Stat Points: 5 |
Topic: Changing 6V to 12VPosted: 26 May 2024 at 7:04pm |
I am doing a total engine rebuild and a restoration on a 1957 D-14, S/N 5242. I need to change the flywheel ring gear as it is badly worn and would like to convert to 12 volt as I have a 1959 D-14 that is 12v. My question is this: the current ring gear is 93 tooth and it looks like available new ring gears for 12 v are 116 t. Also I will need to replace the starter and generator system with 12 volt upgrades. It looks like from specs I have found the 116 t gear will fit on the flywheel. I have converted other tractors and older trucks to 12 v so I think I have the program down, just don't know if the ring gears will fit flywheel that had a 93 t on it. Anyone have any experience with this, or good advice? Thanks in advance.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88649 |
Thanks(1)
Posted: 26 May 2024 at 7:06pm |
read what you are buying.. the 6 volt ring gear goes with the 6 volt starter... 12 v gear goes with the 12 v starter... you can run either on 12 volts... but if you need EVERYTHING, get all 12v PARTS.
vansequipment
Posted: 26 May 2024 at 7:12pm |
Thanks, Steve. That's what I figured. Just wanted to check. I also think I will go with negative ground so I can use LED lights. Lots more light for way less amps. I've done that on other tractors.
steve(ill)
Thanks(1)
Posted: 26 May 2024 at 7:14pm |
https://www.allischalmers.com/forum/allis-chalmers-d14-starter-failure_topic179471.html
DIFFERENT TOOTH COUNT
steve(ill)
Thanks(1)
Posted: 26 May 2024 at 7:16pm |
you might want to consider an alternator with internal reg... as compared to generator with voltage regulator
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24786 |
Thanks(1)
Posted: 26 May 2024 at 7:19pm |
yes, starter pinion gear needs to be changes as well.... I used Delco CS-130 series alternators on my 4 D-14s...no need to trim tin ! just use generator pulley on the alternator. I also used a 2 wire ,1/2" round light in the dash as the 'idiot' light. a 6 volt starter will have a brush shield or band on it, 12v is a 'solid' shell.
vansequipment
Posted: 26 May 2024 at 7:54pm |
Understood, I intend to get 12 v starter to match new ring gear.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5905 |
Thanks(1)
Posted: 26 May 2024 at 7:57pm |
Original set-up from the Factory: D-10, D-12, D-14 Early 6 Volt system had 10 tooth Bendix and 93 tooth Ring Gear. Later 12 Volt system had 9 tooth Bendix and 116 tooth Ring Gear. I get them from NAPA Gary |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3952 |
Posted: 26 May 2024 at 10:38pm |
vans equipment where in washinton state are you located? just curious
vansequipment
Posted: 27 May 2024 at 12:16am |
Arlington, north of Seattle about 50 miles
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Thanks(1)
Posted: 27 May 2024 at 3:37pm |
Original 6 volt generator can be rewired for 12 volts, need a new 12 volt regulator as well.. I have several like that. Starter can stay 6 volt, just spins faster. But since you are changing the ring gear, you will need a starter that mates up to it.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12027 |
Thanks(1)
Posted: 27 May 2024 at 6:12pm |
I offer a complete 12V wiring system if interested. I also rebuild the Starter motors as well. Steve@B&B bb-customcircuits.com
