190xt fuel problem
Wjh6320 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wjh6320 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt fuel problem
    Posted: 23 May 2024 at 4:57pm
Ok my 190xt runs but has no throttle response or power under load. Cleaned both the sediment, fuel seems to flow fine. Changed fuel filter. It will run just fine for a while and then act up agian.
Thinking maybe I need an injector pump rebuild after looking at old post on here. I would just like to work through it before spending the money. Any ideas are appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wjh6320 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 4:58pm
It dies when returning to idle when its acting up
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 6:22pm
Vent plugged on fuel cap/tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wjh6320 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 6:45pm
That’s an interesting thought. I’ll check tomorrow as it’s not close to home. That would be nice
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 2:44am
Where in Upstate NY are you? I'm in Waterloo. Thanks.  Don Jr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wjh6320 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 4:14am
I’m in McGraw, just outside of Cortland.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 6:28am
You might inspect your check valves in your primer pump. One of mine was clogged with debris since I removed the sentiment bowl screen. That's the down side of removing that screen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wjh6320 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 7:10am
Thanks, will try that as well
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 7:41am
There's a very high chance the pump is just due for proper rebuild. These needs serviced on occasion. The internal flex ring breaks down and the pieces plug the return circuit, causing all kinds of odd issues. Losing power and dying is the most common, but non responsive throttle is also common. I'll reply to your pm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 3:57pm
Ed is probably right.  He rebuilt mine 7 years ago.  Mine behaved very erratic towards the end.  It would rev up to full throttle and then die, wouldn't start, then it would start.  Had fuel leaking out of the timing window.  I have a post on here about my complete steps for removal and reattachment below.  It is not a big deal unless you can't see the timing marks.  Fortunately, my sons eyes were better than mine.  The other thing I did wrong was roll the rubber gasket.  Pumped diesel fuel into my oil pan.  Cleaned it out though after I drained it.
I just realized my old post is the number 1 non-paid google search article when searching for "190xt injection pump"!  Good luck and Ed will help you.
