37 wc dowel in rear hub |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Topic: 37 wc dowel in rear hubPosted: 24 Apr 2024 at 10:14pm |
my 37 wc has one dowel in the left hud and five studs . does the dowel pull straight out or thread out ? or deas the hub have to be removed to get it out from the inside ?
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 25 Apr 2024 at 6:28pm |
Parts Catalog doesn't illustrate the Dowell as having threads, appears to be a press fit in to a blind hole.
G |
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 921 |
Posted: 25 Apr 2024 at 7:36pm |
I’m pretty sure that it screws out. We never tried to remove the studs from our ‘37…but our ‘38, ‘39, & ‘41 WCs , as well as our ‘39 RC all have tapped threaded holes in all six holes. I’d try a small pipe wrench or one of the outside “gripper” type stud extractors.
HudCo
Posted: 25 Apr 2024 at 10:43pm |
my right side has six studs itryed screwing it out had to use the rose bud on it i turned it several rounds it dont screw out i will weld a nut on it and hook it to my 50lb. slide hammer on it
Mikez
Posted: 26 Apr 2024 at 7:07am |
What’s the part number. I’ll see if we have it and check it out
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 26 Apr 2024 at 8:51am |
Curious as to why you what to remove it .
