7030 transmission fluid transferring
Orange & silver farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange & silver farm Quote  Post ReplyReply Direct Link To This Post Topic: 7030 transmission fluid transferring
    Posted: 09 Apr 2024 at 4:39am
7030 is transferring trans oil to rear end. I know this has been discussed before. I pulled filters and screens underneath left and right they were pretty clean. Will get new agco. Figured I need to change the seal to stop the bypassing of oil. Anyone have part number of the seal and is there anything else I'll need? (Gaskets) How big of a job is it to change? Am I going about it right so far? Any suggestions greatly appreciated thanks and first time poster
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2024 at 10:50pm
Welcome to the forum.
Yes it is probably best to do as many seals as you can when you are in there.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2024 at 3:35pm
70265398 is the seal causing the trouble. Be sure to wrap one layer of electrical tape on the shaft splines to prevent cutting the seal when installing. Other parts needed: two- 70269665 Orings.....one- 70261282 gasket.......one-70924921 oring.  Reuse all the seals you can as many are obselete i am told.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange & silver farm Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2024 at 4:51pm
Thank you that's what I was answer I was looking for. Wanted to get seals before I started repair
