170 Power director
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: 170 Power director
    Posted: 28 Mar 2024 at 7:05am
Looking at a 170 gasser.  Was shown how the PD when put into low wont stay and bounces back to neutral.  Not an issue in high.  This was shown when tractor was running at idle.   Are we looking at a PD rebuild??? $$$?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 7:11am
Be sure to check high side at full throttle when going from neutral into high side. Yup. new ramp plate for low and probably high side too. I'd guess $1,000 bucks for parts and that's a guess. Last time I bought ramp plates they were $350+ each. Be sure to replace the PTO shifter Oring while split apart.
Edited by DrAllis - 28 Mar 2024 at 8:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 8:27am
Oh dear!  Thanks for the info...hard pass......
Edited by TomYaz - 28 Mar 2024 at 8:28am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 10:34am
A&I had the plates at last check - 70230015 approx  $165  @
Rollers are 70223155 about $20+ @
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 11:58am
Is there any chance that shim adjustments will help at all?
My D-17 (same PD unit, I believe) sometimes pops out of high but never low. It does it only occasionally and I don't work it too hard so I haven't even tried adjusting the shims yet.
A few years ago, I bought two complete PD units on e-bay; one for $66.34 inc. S&H and one for $108.59 inc. S&H.
Strangely, the cheaper one is almost perfect including the ramps.
The ramps in the other one are well worn but the discs are still within usable specs and the shifting collar is in good condition.
Admittedly, I took a chance and it paid off.
Not sure I would recommend anyone else doing this.
At 82, I may never get to swap out the unit but I do have a good one just in case.
It will certainly add to the value of the tractor when it is eventually sold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 12:28pm
Changing shims to try and repair worn out ramp plates and rollers doesn't work. This assumes it is correctly shimmed now and the clutch discs are actually being squeezed together and the clutch doesn't slip under load. I assume far too many things.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 9:27am
You might check to see if the low side stop bolt is still in place. You can remove some of the washers on it to give the lever a little more travel. Also,be sure that the lever set screw is tight and not allowing any play between the lever and cross shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 12:47pm
He means  high range - and the setscrew does loosen up - I have built up the ramps and hardsurfaced the lands and remachined - we have also ground the lands and ramps to have a negative area where the rollers rest in gear - it did not last as the machined area is hard surfaced or case harhened - cheaper to buy new.. but as Doc states - shimming has no affect on staying in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 10:24pm
Sorry for the misinformation. It is the high side that has the stop bolt. The correct fix is probably going to involve new ramp plates and rollers. I have taken off the little plate that has the neutral notch in it and ground another notch to hold the lever from kicking out on at least one tractor. I don't remember now if it was the high or low side that was giving trouble on that tractor. You don't want to have to much preload on the brass shifting collar or it will cause undo wear.
