7060 black belly remote valves
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Topic: 7060 black belly remote valves
    Posted: 15 Mar 2024 at 8:35pm
Working on getting the remote valves working better on our 7060.  Replaced the large pin, levers, and the pins on the front of the spools. Man 40+ years of wear and its amazing how they feel now! Third remote detents in lower and raise and goes into float.  1+2 remotes do not detent or go into float.  Took the rubber plugs out on the back of the spool and oil came out.  I assume valve spool needs resealed.
But, the question is.  Why do those two valve not detent or go into float?
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2024 at 9:02pm
Id start with the adjustment inside where you took the plug out. I dont have 7000 series now but it seems that they were an allen screw. My 8070s are a small screwdriver
If that doesnt fix it theres something wrong with the detent mechanism but ive never had one give trouble other than adjustment
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 7:57am
With the engine off, you should have those detents in all of the levers. Readjust the cables if you don't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 10:23am
If you push the lever forward toward lower and it doesnt detent its not the cables because you have more lever and cable stroke to go to float
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 12:10pm
Ya I need to unhook a cable on the ones that do not detent and see if I can manually detent reaching up there. Then I know it’s a cable adjustment I guess.
ryan
