Allis B throttle
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B throttle
    Posted: 09 Mar 2024 at 7:23am
My throttle goes about halfway up before the engine starts to rev up. Is something worn out or does it need adjusting?
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2024 at 8:05am
Push the lever to WIDE OPEN.... Check the governor arm to see that it is WIDE OPEN.... Look at the Carburetor lever to see if it is WIDE OPEN..... If everything on the governor and carb is adjusted right... go back to the lever, loosen the square set screw and push the 1/4 inch rod forward 1/4 inch and lock the screw back down...
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2024 at 3:24pm
Ok everything you mention seems to be ok. Have not adjusted the rod yet, seems like a 1/4” wouldn’t do much. At idle position to 1/2 way does not change anything. At 1/2 it goes to full throttle. Nothing in between.
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2024 at 6:06pm
I would assume an adjustment of the lever/ rod would fix that... If not, we can give directions on how to "SET" the governor to the carburetor linkage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2024 at 6:10pm
STarting at the carburetor lever, there is a ROD that goes toward the radiator and pins to the GOVERNOR cross arm running behind the radiator to the governor.. Pull the carburetor ROD off the governor cross arm....
Push the hand THROTTLE lever (at the seat console) WIDE OPEN ( full forward).... see that the lever / spring on the governor has been stroked FULL OPEN ( spring stretched)....
Now go to the carburetor and pull the ROD full forward toward that Governor cross arm that you disconnected.. ( make sure the rod moves smoothly from the stop to full forward. Make sure the carb ARM is not dragging on the engine block wall....pull the ROD all the way forward... See that the carb ROD lines up with the HOLE in the gov cross arm.. If not, BEND the arm forward or back until the rod just lines up, and reinstall... test again.
Edited by steve(ill) - 09 Mar 2024 at 6:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2024 at 8:05pm
Thanks Steve. Sunday will be a busy day, but I will check it Monday.
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
