5020 transfer case
BGF250 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BGF250 Quote  Post ReplyReply Direct Link To This Post Topic: 5020 transfer case
    Posted: 24 Feb 2024 at 8:24am
I'm looking at buying a 5020. Everything is good and works except it will only go into High and Low. Medium will not engage. Anyone familiar with this problem? Should I stay away from this tractor or can I just run it in high/low without problem?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 9:31am
Parts are near impossible to find.  Are you looking at buying it because it's cheap?  It's cheap for a reason.  Run away.  Many better choices out there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BGF250 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 10:47am
That's how I'm starting to feel about it. Maybe I'll recommend he post it here for parts if nothing else.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 11:38am
Are you sure it not an 8 speed? Dale
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 12:37pm
at SN 2691 there was a creeper gear range installed.   'Medium" if above that SN would be from about 1.0 - 2.5 mph and high from there to about 8 MPH - low or creeper would all be below 1 MPH  - per memory... if at high idle in low range 4 th gear you are just above 2MPH you have an 8 speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BGF250 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 7:07pm
This guy says it high/med/low. I haven't found much info on the 12 speed, so I assume that would be how the 12 speed works. I'm just afraid 4th gear a in low will be too slow and 1st gear in high too fast. Anyway I'm gonna keep looking. Let me know if somebody's interested and I'll pass his info along.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 8:03pm
2wd or fwa?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BGF250 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 8:14pm
It's 4WD. Check Denver Craigslist Farm and Garden. He just reposted it today. He's asking $5,500
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 10:35pm
That's rich for a working one!
This page was generated in 0.071 seconds.
