175 GAS STARTING ISSUE
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: 175 GAS STARTING ISSUE
    Posted: 20 Feb 2024 at 7:18pm
HELLO
 I'VE GOT A 175 GAS REPLACED THE CARB. HAD NO LUCK REBUILDING ORIGONAL ,CONVERTED TO ELECTRONIC IGNITION , FOR THE LIFE OF ME I CAN'T GET THIS TRACTOR STARTED.
I'VE GOT A BUDDY THAT PICKED ONE UP THAT HAD BEEN SITTING UP FOR 6 OR 7 YEARS AND HAS POINTS , PUT GAS AND A HOT BATTERY AND SHE STARTED RIGHT UP.
 AS LONG AS WE'VE BEEN HAVING THAT TRACTOR SHE HAS ALWAYS BEEN A MOTHER TO START , TURN ,TURN,TURN, A LITTLE CHOKE  THEN SHE WANTS TO FLOOD OUT AND IF SHE'D START YOU'D HAVE TO HOPE SHE'D STAY RUNNING TILL SHE'D WARM UP, AT THIS POINT I SWARE I'D SELL IT FOR SCRAP.  ANY HELP WOULD BE APPRECAITED
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 7:40pm
Have you made any checks on compression or ignition?  Sometimes its more than 1 problem...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 8:52pm
If you have spark and gas.......... i would check the TIMING... Several degress off will make them HARD to start. ...... could be the point slipped or burnt contact and that changed the timing.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 10:17pm
also check valve lash
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 2:06am
Check the voltage while the starter is turning. Electronic ignition needs 12 volts to fire. If your voltage drops while the starter is turning it will not start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 6:26am
"Borrow" a known good-starting carburetor from a WD45 or D-17 and try it on this hard starting engine. Still doesn't start good, it ain't the carb.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2024 at 4:01pm
How old are the spark plug wires and what brand spark plug are you using?
