Allis Chalmers D14 Head Bolts
ForeverHomestead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ForeverHomestead Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D14 Head Bolts
    Posted: 15 Feb 2024 at 4:46pm
Hello All.  I am putting my D14 back together and thought maybe I could get away with reusing my head bolts (I know I am not supposed to)  as I am having a hard time sourcing new ones.  However when I was tightening them down, two of them stripped the threads.  So now I am on the hunt.
Can I use  grade 8 bolts?  if not, does anyone have a source for them they can send me a link to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 6:47am
Grade 8 bolts will be fine if you find the correct length. IFIRR some are on the 1/4" increment, most places only stock the 1/2" increment sizes.
  You're lucky that the treads stripped off. Many years ago when reusing old bolts, I've had them break just as I was getting to the final torque. I never reuse head bolts any more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 7:07am
Be sure to run a bottoming tap down each and EVERY head bolt hole and with compressed air clean them all out good. Wipe some grease on the threads of the head bolts for lube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ForeverHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 7:09am
thanks for the help guys.  I did clean the threads out with a tap.  I found a match on length and installed them yesterday .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 8:10am
Looks like head bolts are still available
