7000 Series Monitor & Controls Mounting
CDN 400 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Series Monitor & Controls Mounting
    Posted: 11 Feb 2024 at 2:02pm
I am just wondering how everyone is mounting monitors and electric controls in there 7xxx series? I don't see a lot of solid structure to mount to, pics would be a big bonus.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 3:38pm
My 7040. PO had already drilled the holes so I adapted to it
Planter monitor is attached to the roof in the 7045 behind the rear view mirror. There were some existing bolts I adapted to. Note in black belly cabs with all the foam i use longer bolts with sleeves so as not to crush the foam. This is how they did it for the ash tray and light fixture over the hydraulic controls
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 4:53pm
On our 7XXX, built a stand that bolted to the floor, in front of the right lower window, then a single brace back to the cab frame. Sorry don't have any pictures, this was done a long time ago.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 7:48pm
Made a a pole mounted from the right front corner. 1” pipe holds a Trimble 250, Raven 4400, and then the boom function box for the Top Air sprayer.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2024 at 4:40pm
Thanks for the replies ,they gave me some good ideas to build from.
