D19 power steering fluid
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: D19 power steering fluid
    Posted: 05 Feb 2024 at 3:43pm
Books say type A atf as per 1961. Can I use hytrans? Or just the atf? Thank you. Dana
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 3:49pm
hytrans -  ATF fluid -  10wt - or steering fluid from the auto store...
If you use the ATF i would use type A or F... The newer Dextron and MERCON fluids are synthetic and lots of addatives... Old tractor seals might not like that.
Edited by steve(ill) - 05 Feb 2024 at 3:51pm
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2024 at 3:50pm
hytrans is ok
