Help on steering on WD45
TEDINMO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TEDINMO Quote  Post ReplyReply Direct Link To This Post Topic: Help on steering on WD45
    Posted: 26 Oct 2010 at 2:30pm
My brother has a wd45 with the wide spaced front  wheels, the tractor has set for a year and I  helped him get it running yesterday.  Problem is that the steering is locked up, will not turn right or left, has fluid etc. but nothing moves but the steering shaft a small amount when you turn the wheel.   Any suggestions? Thanks for any help.
Any ideas on this, Help please. Surely someone has had this problem. We have never worked on a frontend on this tractor before, any idea what to look for? I work on classic cars and hot rods, not tractors.      Thanks
Edited by TEDINMO - 26 Oct 2010 at 3:47pm
Andy in Central IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy in Central IA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 7:01pm
Does the tractor have power steering?
Andy Central IA
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 7:42pm
I'm like Andy, Does it have power steering? There are a lot of us Wd45 guys around the KC area to help you on this. Don
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 8:12pm
He said it has fluid, so I would think that it has power steering. Take the steering shaft loose at the output end of the torque generator and determine if that is the problem. If the torque generator is okay then jack up the front end and check to see if the spindles are stuck, I can't imagine that they are but it is a cheap, quick thing to do. Oh yeah, is the belt on the powersteering pump and turning when the engine is running?
Basically narrow down where the steering is stuck, we can help you from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 8:26pm
My WD45 with Char-Lynn power steering steered like tank until I got the hood off and added ATF fluid to the power steering reservoir....now it steers GREAT!  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 9:58pm
If it is factory power steering, the needle bearings may have come apart and are locking the gears in the steering unit.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote TEDINMO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 10:48pm
Thanks for the replies.  It is power steering, and I will check on it some more with your suggestions.
Thanks
