190 XT gear reduction starter
CW2 Ryno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT gear reduction starter
    Posted: 29 Jan 2024 at 11:12am
This Probably been posted many times but as I read through the posts.   I had questions.   Is there a gear reduction starter from another series that will fit a 190XT series 3 ?    Just curious what others have found or used. And if any modifications were required.
Thanks,
Dale
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 12:02pm
I believe it was the 6080's Denso starter that was the original factory application.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 8:06pm
Thank you!
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 11:08pm
I've used a Nippon Denso #028000-6780 on AC180 & 200.
Replaces Delco 1113657 and Allis 70242143 and 79004832 starters.
 parts store catalog says it fits most; 180, 185, 190, 190XT, 200, 7000, 7010, 7020, 8010 using AC 301 CID engines.
 There's also 1 that replaces these engines using the LUCAS starters, but I can't find its part number.
