Shifter knob removal 8000 series?
gleaner1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Topic: Shifter knob removal 8000 series?
    Posted: 26 Jan 2024 at 8:14am
Has anyone attempted removing with destroying them? I need to remove and they don't appear to be threaded on.
Thanks in advance.
ALLIS CHALMERS "The color is orange"
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 8:22am
Pull strait up, don't punch yourself in the jaw doing so !
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 8:33am
I take a pair of bigger vice grips and put on the shaft just tight enough to slide on the shaft and still be able to tap on the bottom of the knob with a hammer and it'll slide the knob off, there's a clip the holds the knob on the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 8:47am
Like maybe clamp tight a 1/4" nut in the vise-grips teeth and they will still easily slide up and down on the handle like a slide hammer ??
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 5:45pm
I've got a knob on an 8070 pd lever that I can't keep on! Tried several types of glue, nothing holds. Idea's?
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 5:58pm
New tolerance ring AND weather strip glue like 3M brand 8001.
Edited by DrAllis - 26 Jan 2024 at 5:59pm
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 8:04pm
I used a 2 part epoxy and an Oring under the ball to keep the glue contained. They aint coming off!
WD,D15,190XT,7000,8010x2,7060,8070
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 12:13pm
A rubber hammer should be able to knock it up and off. Thats what ive used. The ring that goes inside that holds it on is discontinued from Agco or was last time i was looking. The knob is still available, cant see why you cant get the ring too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2024 at 8:23am
Couldn’t you thread it. Then the option of knobs to choose from is endless
This page was generated in 0.057 seconds.
