D17 Spindle Removal?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: D17 Spindle Removal?
    Posted: 18 Jan 2024 at 5:39am
Snapped a spindle on my D17 S2 the other day.  Any tips/tricks to getting the steering arm off?  Really don't have access to heat.
AaronSEIA
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 6:43am
If it were mine I would grind off the bottom, remove the remaining spindle from the top. Set it in a press or support it so you can hammer the the rest out. I have the knee assembly on the shelf and would just replace the assembly. It gets easier when you drag home parts tractors.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 6:53am
Remove the knee and turn it upside down and drive downward with a 20 lb or more sledge hammer. Solid blocking is important for a good hard hit.
This page was generated in 0.057 seconds.
