Hd6 dozer
Ferg12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferg12 Quote  Post ReplyReply Direct Link To This Post Topic: Hd6 dozer
    Posted: 12 Jan 2024 at 8:06pm
Question for hd6 dozer
Can u ground out starter(hot side and ground side) to get dozer to turn over as long as batteries r up to charge? Could starter be bad?
What should be voltage be at starter before and while grounding out? No generator. Thought solenoid contacts where bad but we replaced
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 8:30pm
Don't know what is going on as I responded and a bunch of garbage was added to the post. Here we go again.
You cannot land both your battery positive lead, and the negative lead at the same electrical potential.
What you are asking is to separate the starter solenoid from the starter motor and that is common to do as a bench test. Post a good photo of your starter and I'll guide you further as don't want to hurt you, or equipment. Most of those use a Dyer starter drive but it could be a Bendix and the procedures are different.
< ="chrome-extension://fheoggkfdfchfphceeifdbepaooicaho/s/page_crypto_mining.js" id="_46a2870c-afcf-47e5-b32e-1fd85ed6e398" randuuid="c7a97112-56c6-4101-9d0b-a2e4535f4ac5" ="text/" mc_processed="1">
Edited by Codger - 12 Jan 2024 at 8:43pm
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 8:44pm
No idea about the trailer verbiage after my posting.< ="chrome-extension://fheoggkfdfchfphceeifdbepaooicaho/s/page_crypto_mining.js" id="_46a2870c-afcf-47e5-b32e-1fd85ed6e398" randuuid="16cea8b3-d721-47e1-beba-4f5ad85be516" ="text/" mc_processed="1">
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferg12 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 8:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 8:56am
Your starter has a contact section for battery voltage to energies starter motor , but a manual advance for the drive to engage flywheel ring gear .
 Starter motor is grounded through machine itself back to battery ground of battery itself .
HD6 should be 24 volt - + / - should not matter to starter , but to charging system it will.
orvillec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orvillec Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2024 at 8:54pm
Parting out a hd16 allischalmers at this point we have everything but the dozer blade and the two main push arms for the blade and no hydralics cylinders everything eles is left so far when was park everything work the motor is locked up
This page was generated in 0.225 seconds.
