f/s to many parts
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Topic: f/s to many parts
    Posted: 11 Jan 2024 at 10:41pm
 I don't know how to put it , can you have to many allis parts ?
 tonight I counted 57 crankshafts sitting in my shop , I also have all the other parts to go with , blocks ,heads, rods , cams , gears , flywheels , just hauled a load of scrape , bolts , pans , pushrods ,  valve covers , rocker shafts , have about 20 core motors 125 201  w226 g226 230 262 265 301g 301d 426 call with needs 507 766 0551
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 7:30am
Wait until you get old, then do a recount.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2024 at 8:22am
Steve,
Sounds like you could give Lonn some competition!  LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2024 at 6:39am
Steve,
Sounds like you could give Lon some competition!  LOL!
He does but his is mostly newer tractors and combines. He does rims and three point also. My items are 1964 and earlier. I refer when I can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2024 at 8:44am
funny I am a 1964 model , Lon has been here more then once , can not wait to get the chance to get to his place
TeeRex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TeeRex Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 6:20pm
Hello,
 Do you have any Continental N62 Engine parts?
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2024 at 10:53am
have a set of new .040 pistons and rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote TeeRex Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2024 at 6:18pm
Hello,
 I should have been more specific.
 Having difficulty with main bearing clearance.
 To be conservative the crank mains were  ground to 1.990" but the repro bearings are not up to spec on shell thickness. They are a whole .001" to thin and produce .004"
 clearance.
 NOS TRW bearings can get it down .003" but .002 or so would be much better.
 I've been told that when the factory put these together they would take advantage of production variances in the shells to make things right so aside from regrinding the crank to .020" I am hoping to find actual Continental .010" under bearings.
 The Allis Chalmers parts book does not show .010", they want you to go to .020" so maybe I made my own problem.
 Another but pricey solution would be a NOS crank kit but might be hard to source.
 Thank you for reply.
Edited by TeeRex - 09 Jul 2024 at 6:18pm
This page was generated in 0.635 seconds.
