Sticking Clutch Pedal on a Allis Chalmers 8070
toasty_osty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toasty_osty Quote  Post ReplyReply Direct Link To This Post Topic: Sticking Clutch Pedal on a Allis Chalmers 8070
    Posted: 05 Jan 2024 at 9:35am
Hi, I own a 8070 that has recently been having problems with the clutch pedal sticking. I’m trying to figure if I can adjust I or if I need to replace anything. Thanks
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2024 at 2:01pm
Probably the cable
You could unhook it at each end alternately
to determine if its in the cab or cable or valve
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2024 at 3:45pm
If it's a power director tractor, it's probably the clutch cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2024 at 5:45pm
If the pedal doesn't come clear to the top by itself, it could also be the down-shift switch worn out or needing a shot oil oil on it.
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2024 at 9:36am
Replaced my 8070 Power shift clutch cable last year.  Actually pretty easy job to do. I don't think it took me more than a half hour to change out.  I did attach about 4 ft of weed eater string to old cable on the cab side.  Pulled cable out from the valve side.  Pulled in new cable with the string.  Amazing how much easier the pedal moves now.  I need to do my 8030 also. To troubleshoot, I unhooked on both ends and couldn't move the cable by hand or with a pliers.
This page was generated in 0.281 seconds.
