Homemade Snap Coupler Implement
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: Homemade Snap Coupler Implement
    Posted: 02 Jan 2024 at 5:52pm
I would like to build some pallet jacks for the snap coupler. Has anybody built something that would work and have pointers?
I have a 200 gallon water tank I want to build into a sprayer. It seems pretty straight forward to me, but ideas, suggestions and warnings would be appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 6:02pm
Lots been made with heavy 3" x 3" angle iron in an "A" frame tongue to the snap-coupler bell and twisted link chains done in a "V" to a cross bar to control sway. Attach your tool to the crossbar, which could be the same size angle iron on the pull tongue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 6:42pm
the simple way would be to build something like this with  lower arms 2-3 ft longer and set the tank on a couple welded on cross braces... Realize that as you raise the load, it will pivot on the bail and the back end raises faster than the front, so the load does not stay level.. Probably not a big deal on a water tank....
If you want to stay LEVEL like using forks, then you need the snap couple hitch like this, with a 3 point BOX or deck behind that with correct geometry to the top link..
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 7:40pm
Would it be easier/better to try and attach a spray boom to the cultivator bar? I can take the tines off so it's basically a tool bar. I could then lift the water with the loader.
I'm just not sure my loader will lift 200 gallons of water, and I was hoping to take it off when I was done moving snow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 8:02pm
you might be able to lift with the loader... but will you be able to steer ??
DMac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMac Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 8:04pm
i plan to build one myself.  I have a 3point hitch 2 spear bale spike that I plan on starting with.  I got an old wd drawbar with the ring  that i plan on welding to the front and figure ill make a couple pieces to fit the snap latches and weld them in the correct location on the arch of the implement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 9:22pm
I have power steering. But probably not gonna steer well enough to stay within rows. Good point.
The lifting connection arms are what I'm not totally clear on how I'm gonna do. I feel like there should be an easy way to repurpose top links. But nothing's coming to mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 9:46pm
are you trying to eliminate the snap latch and just run a  adjustable bar  from the lower arm to the lift arm ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 10:35pm
Something like this is what I'm thinking. None of the dimensions are figured, and the enigneering isn't done. I would the build a box to sit the tank on between the 3" x 3" tubes. The lift arms aren't adjustable, but not sure they would need to be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 10:41pm
With a slight modification, could put some hydraulic cylinder on it and the forks to make the forks levelable - wouldn't be self levelling like a 3 point. But if I really cared there would be options.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 10:41pm
that should work OK.... The vertical bars dont have to adjust... but they have to pivot at both ends....
just realize that the "LIFT" is going to pivot on the front Bail hitch... so the back end of the tank is going to swing thru an arc as it raises... Not a big problem.... thats basically how all implements on the snap coupler work.
Nice drawing...... what program ? ..... part of your work/ job ?
Edited by steve(ill) - 02 Jan 2024 at 10:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 11:39pm
that should work OK.... The vertical bars dont have to adjust... but they have to pivot at both ends....Nice drawing...... what program ? ..... part of your work/ job ?
I'll also probably add plates in an "X" shape between the vertical arms to stop it swinging left and right. My grader and cultivator do that.
SOLIDWORKS. I'm an ME in education and detailing engineer by trade. Play farmer on the weekends.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 7:23am
I miss having Solidworks available to me now that I am retired, it sure is a sweet design program
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 7:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 8:00am
oopsy forgot to add..
made this 20 years ago, 42" forklift forks hang from it, will lift 2500# logs.
OK, she ain't a purdy store bought gal, but has worked GREAT since day one !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 8:12am
That looks great!, and simple! You must back up to it, clip the lift arms on, and then swing the drawbar hook in?
Do you have any sketches or dimensions for it? I'll probably take my own, but a concensus would be great.
Are those lift arms pinned to the bottom? Does that make the forks lift level?
Edited by MadCow - 03 Jan 2024 at 8:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 8:15am
I always say I get to play on the computer all day. There's nothing quite as slick as solidworks. Fusion 360 is close - but it's not free anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 8:32am
Jay has a nice , simple hitch right there... The Pivot bolts at the boot would appear to be the weak link if any.  A clevis or saddle that holds both sides of the arm would strengthen the frame..   Since the 2 x 2 hitch is connected to the lift arm instead of the lower arms it would tend to LIFT more horizontal... Dimension / placement of the vertical lift frame would determine how LEVEL it lifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 8:41am
one thing you can do is make a little frame from plywood and 2x4 for a test.... make it so you can easily move the lower pin point forward and back. and change the HEIGHT of the frame up the to lift arms.... I did that with a set of forks to put on a "B" 3 point and figure the best Dimensions to get it to lift LEVEL.
you can also draw it out on a piece of graph paper showing the LOWER and RAISE positions of the lower arms and upper arms... then measure various places on the lower arm and the height of vertical bars to try to get somewhat LEVEL lift design... PRIOR to cutting out any parts.
Edited by steve(ill) - 03 Jan 2024 at 9:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 8:46am
1/2" grade 8 bolts, lower arms are 1 1/2" square tubing, the "U" I bent by hand,lift latch pins are 5/8" bar so uprights are 1 1/2", 2" sleeve with 2" center 'post', 2" angle iron for cross pieces.
built it after getting the forks for free( dumpster dive), replaced the FREEMAN loader, so no real plans.... made the 'arms' first,long, then cut to length after making the snap coupler section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 9:51am
You actually made me rethink my whole design. Probably do something closer to what you have. Then the frame that holds my water tank can have the same "hooks" that a pallet for has, and I can just back up and grab it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 10:01am
Mine has hauled 1,000s of skids as well as 20 IBC totes..here,there, everywhere...
it even hauled tandem pull discs 2  miles to friends farm several times(stuck 'pole boom' into vertical tubing, several chains....kinda swayed a bit but everyone stayed away from me !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 12:33pm
MadCow .... if you make a drawing, post it so all can see. I would be interested in seeing your design.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 4:31pm
I've got the real thing. AC SC pallet forks. They work pretty slick. If I can I'll find pics.
Edited by exSW - 03 Jan 2024 at 4:38pm
Learning AC...slowly
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2024 at 9:08am
Rev 2 layout. I'm thinking the lower bar should be offset from the upper bar, so that when the lift is down with the forks on the fork tynes would be angled to parallel to the ground. The height of the top tyne carrier will need to be figured so that when the lift is all the way down, the tynes will be on the ground. Which may vary depending on the tynes used.
I used round bar on the bottom, because I'm thinking with a little modification of the layout you could adapt a universal skid steer connector to fit on this, with a couple hydraulic cylinders to control the pitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2024 at 1:41pm
Got around to making a drawing. Anybody think this will work?
The 1/4" holes in item 5 are for washers and pins to hold the lift arms in the right place - may or may not be needed.
Very little welding, but I would probably need someone to do the bending - not sure how to get around that.
It *should* be able to go from all the way down - to touching the ground so the lift arms can pick it right up from the ground - to all the way up. On a D15 at least. Struggled to get it to avoid the pumpkin - but I will hopefully be building this in the next month or so.
With little modification to the 1" bar should be able to get a skid steer universal quick attach to work on it - maybe even with some hydraulics.
uploads/24122/whole_assembly.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2024 at 4:19pm
From a Welders point of view... I would not bend anything.. Cut and weld all the corners......... guess it depends on access to a bender, and you welding ability..
do the uprights #3 rotate with respect to the frame #1 ? .... what locks them together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2024 at 4:39pm
Easiest way would be to find an old SC plow or bush hog and pull the tongue, eye and lift arms off of it.  That way you only have to attach the rest of it to the pivot hole already in the SC frame.  I do know that a SC bush hog frame is mighty close, width wise, to cat 1 3 point hitch...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2024 at 5:03pm
Welding ability is yet to be determined - I figured it'd be easier to find someone that could bend them while I wait, for cheaper, than I could find someone to weld the quality needed at the angles. Where the flats meet together there's a lot of space and a lot of weld I'm not too worried about sucking.
Yes they rotate. They are "locked" together by the 1" rod (5) going through them. Putting pins and washers on the outside of #3 to hold it together. There may need to be pins on the inside to stop the beams (1) from pinching together - but I don't think I'll need them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2024 at 5:06pm
Implements in general around me are. About 4 times higher than elsewhere in the country - and AC stuff is almost non-existent. It's almost cheaper to ship LTL from 14hrs away than it is to try and buy old implements locally.
I've seen people post single row model 70 JD planters on a cobbled 3pt hitch with obvious rattle can paint for $1,500 and the post isn't up for more than 72 hrs before it's sold.
This page was generated in 0.139 seconds.
