430 corn head
CCF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCF Quote  Post ReplyReply Direct Link To This Post Topic: 430 corn head
    Posted: 21 Dec 2023 at 3:32pm
Any one have dimensions of 430 corn head main actual width, length and weight trying to get shipping quotes
Thanks
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2023 at 3:44pm
need more specifics please..  Orange or black frame?
BLACK 430 as follows:
weight: 2400 lbs,
width: 126.4 inches,
length: early short snout ~ 105 inches,
length: later long snout ~ 113 inches.
Edited by AC7060IL - 21 Dec 2023 at 4:05pm
CCF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCF Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2023 at 3:46pm
Black
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2023 at 4:21pm
The A430 Black gleaner corn head is designed to be shipped horizontal(laying flat) or vertical( upright). Most US state's DOT allows trailer width up to 102" (8'-6") as non wide-load so can transport day/night hours within LOG hours. So if the 430's length of 105 or 113 inches is an issue, it can be positioned on trailer vertically. To do so, both lower rear jack stands will mount for horizontal or vertical positioning. In vertical position, a loader/forklift of some sort is necessary to load/unload it into/out-of that position on trailer. And then wooden support blocks under the corn head's upper throat frame can help eliminate/minimize any potential tin work damaged.  And,, going to want a minimum of 4 chains to secure/stabilize corn head's 4 corners to trailer. Or, snouts could be removed & stored elsewhere?
Transport by Sea-land container ~ vertical position. If height is an issue, then remove snouts.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2023 at 10:20am
Remove the front portion of the snouts narrows it up to esily ship without ovewidth permit layig flat
thats way i truck them
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2023 at 10:32pm
hang it over on the ditch side and drive.
If hiring a trucking company, best bet is have the snouts removed and the header left flat for transport. Im not comfortable going up on its back unless there is a mating header and they can go face to face.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
This page was generated in 0.586 seconds.
