D17 S1 - Lift Housing Drill & Tap
bendts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Topic: D17 S1 - Lift Housing Drill & Tap
    Posted: 10 Dec 2023 at 8:49am
Finally getting my 3-poit set-up installed and have read that many likes to drill and tap 1/2" threads in the lift housing for the upper link bracket.
Or would a 3/4 tap be even better?
Is it necessary to remove that entire housing to do this? Or can I just drill and tap with a shop-vac and let any of the internal metal shaving settle and do a oil flush to get out the worst of it?
Planning on tapping the existing PTO Shield holes or going a bit wider with 2 new holes in the thicker lower section only.
Thanks
1960 D17 Gas # 28849
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 10:33am
I've only done one over the years. I redid the existing 3/8" PTO shield holes to 1/2" NC thread Gr8 and was careful not to break thru to the inside and loctite. To go 3/4" would not be my choice. My bracket was homemade and I purposely shaped it to fit flat on top of the lift arm housing at the rear and drill two 1/2" holes down from the top into the lift arm housing and then extend forward to the seat mtg holes. The two holes on top I broke thru and nutted them on the inside with the housing removed. Loctitie seal everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 2:08pm
Great Thanks - I'll give that a shot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 3:17pm
You will find on that tractor, a shorter top link is needed and usually should be hooked higher up and away from the PTO shield bolt area. It's the geometry of the hitch.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2023 at 7:48am
I have an aftermarket top link bracket for sale. I just thought I would through that out there . $75 if you are interested.
http://lonsallischalmers.com
