WD muffler question
Tom75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom75 Quote  Post ReplyReply Direct Link To This Post Topic: WD muffler question
    Posted: 07 Dec 2023 at 6:36pm
So the muffler on my WD is loose and loud!   The bracket on the side of the manifold wasn’t holding much so I removed it and was going to replace it. My question is, is that bracket the only thing that holds the muffler in there? Looking on line I don’t see any kind of an exhaust donught/gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 7:01pm
There was more than one type of manifold for a WD and each one had its own muffler. Pics needed.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 8:48pm
I ordered a WD 45 manifold (actually seems to have replaced both WD and WD45) off yesterdaystractors along with a muffler.
The new manifold was designed for better air flow so in theory you'll get a little HP increase.
The manifold had a screw in pipe and the muffler shingled over it. The bracket style risks more water intrusion than this replacement.
Be sure to get the manifold to engine bushing kit.
And I got a flapper top for the muffler. I still put a can over it when it sits for a while.
Edited by jvin248 - 07 Dec 2023 at 8:55pm
