Throttle linkage on D17 series 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Throttle linkage on D17 series 4
    Posted: 24 Oct 2010 at 2:52pm
On the throttle linkage on my D17 series 4, right underneath the gas tank, there is a small rod that comes forward that on the end has an end with a ball joint on it, that snaps into a socket piece for the next series of the linkage.   this ball and socket piece is worn out and the ball falls out of the socket.   I looked page by page under AGCO's online parts catalog, and could not find it listed on there.   I was wondering if anyone knew if these two parts were available yet, or where I could go to find them.   I would like to get this fixed before winter as the baler wire that was holding it doesn't let it pivot good, and I don't want it to be broken in the middle of winter as I use this tractor to clean the driveway.   I will try to take a picture of the two pieces and post on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 2:58pm
Here is a picture:
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 3:43pm
I had one of those on my Case 830 . I took it off and put it in a vice and used a small punch and hammer to close the hole around the ball.  My D17 is held togather with baleing wire also, has been good for years.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 3:50pm
I bought one from my AGCO dealer a couple years ago.  I'll look for a part number...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 3:55pm
230339 would be a starting point...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 4:38pm
Thanks Russ,  I used the number and it pulled it right up.   Now at least I can call and gasp when they tell me how much it will be!!   That is if it's still available.
Edited by ChuckLuedtkeSEWI - 24 Oct 2010 at 5:11pm
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 5:33pm
I got 2 of them a year ago from my AGCO dealer. $11.24 each. I thought that was a pretty good price.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 5:36pm
I used a hammer and punch and pinched it together again. very easy to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 7:40pm
Mc-Master Carr has them for like $4-$5.  Thanks for reminding me to put that on my next order.   Mine came apart on my Series III D17 a couple months ago and I did exactly what Matt MN did to patch mine back together.  He's a link to page at McMaster-Carr.  Mike
http://www.mcmaster.com/#ball-joints/=9f601a
Also reminds me I have to measure the ball joint ends on the steering drag link on my Allis 716H mower and get them too at Mc-Master Carr - same page.   It too came apart about the same time!
Edited by Skyhighballoon(MO) - 24 Oct 2010 at 7:43pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
