Allis Chalmers D17 Propane Side Shields |
CORY
Topic: Allis Chalmers D17 Propane Side ShieldsPosted: 07 Dec 2023 at 11:37am |
Are the bottom halves the same as a gas tractor? Or does anyone have a picture of a set off the tractor? Just trying to figure out what is missing on my recently acquired propane.
Thanks Cory
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 07 Dec 2023 at 6:07pm |
Here is a Link to pictures of a D-17 Propane which has side panels below the Propane Cylinder. G https://www.mecum.com/lots/322759/1958-allis-chalmers-d17-lp/ |
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2312 |
Posted: 07 Dec 2023 at 9:04pm |
You can make them out of gas tractor side panels.
However There is an additional panel/cover that goes between tank and instrument panel. It most often is missing. |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4284 |
Posted: 08 Dec 2023 at 8:58am |
Cory, is you're tractor an original propane or a conversion? They did quite a few conversions on 45's, I assume they did 17's too. At any rate, the sheet metal would be different.
CORY
Posted: 08 Dec 2023 at 10:26am |
Factory LP Series II. The shield underneath the tank going around to both sides is there. It appears as in the picture that was posted as well as on mine that the side panels from a Gas would bolt right in there.(I have not taken the time to try as the tractor is currently at work and not at home) What is odd is there is part of the one underneath the tank on left side as sitting in the seat but it appears to be a factory? cut right where the steering shaft comes in at an angle. I would gladly text pictures to someone that knows how to post them on the site.
Mikez
Posted: 09 Dec 2023 at 7:54am |
Parts book just lists same panels for both gas and lp. Just has additional panel extension under tank.
