Martinsville Weight on WD
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: Martinsville Weight on WD
    Posted: 02 Dec 2023 at 8:45pm
Had someone send me a picture of their WD with rear weights on it that are not the regular AM 2795-10 Allis weights.  They say Martinsville Ill WD-D17 on them and are shaped different than the Allis weight.  I had never heard of or seen these weights before on a WD/WD45.  Were they a common type after market weight made to fit the 28" rim?  Thanks, Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 12:42am
Common around here. Have 2 sets. Guessing 150lb apiece. Martinsville about 60 miles away. Went to their foundry for field trip in 75. Was young and didn't pay much attention....
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 8:19am
nonetheless ,still dead.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 11:45am
Got a couple sets of the heavier ones, 300 lbs. or better. No need for fluid when you double them up. Fit 28 or 30 in. tires. Like Steve mentioned, real common around here.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 12:30pm
I've got a pair of locally made ones on my "39 Allis B.  Made by Norwood Foundry in Edmonton, Ab., 30 miles away.  They're about twice the weight of the common Allis weights. Came with the 'B' when I got it over 25 years ago.
