UC Trans Oil |
Unit3
Topic: UC Trans OilPosted: 14 Nov 2023 at 7:33pm |
When it’s time to change out that heavy old grease/oil that is in them, what do you recommend to use?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8685 |
Posted: 14 Nov 2023 at 10:26pm |
I put 80-90 in mine. Not sure the old 140 will drain unless heated up. Had mine apart in 1974 for a bearing in trans. Think I dug a lot of the goop out by hand before gasoline bath. That was a long time ago so memory could be off.
GreenOrange
Joined: 11 Sep 2009 Location: Wisconsin Points: 851 |
Posted: 16 Nov 2023 at 9:16pm |
I run SAE140 GL-4 in mine. Not the easiest to find and takes a lot of oil (12 gal I seem to recall).
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 17 Nov 2023 at 7:32am |
run 80-90 in mine
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
