Model C clutch return spring
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Model C clutch return spring
    Posted: 14 Nov 2023 at 6:07pm
I am installing the return spring.
Per picture below, the forward end is attached to cotter pin's head.
Where does the other end go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 6:30pm
There should be a hole between the pivot hole and the clutch rod hole for it to go in. They did use different springs for different years and it might just hook in the cotter pin for the pivot back at the peddle.
Edited by PaulB - 14 Nov 2023 at 6:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 11:32am
I installed it per PaulB.
Painted end with a dab of white, you can see it protruding from the hole.
